Topic: babyface pro output channels other than 1+2 visible but not working
i'm using ipad pro + AUM + babyface pro with apple usb / usb-c connector.
I'm trying to send some sound to channels other than the main stereo out 1+2.
In AUM, I can see the long list of usb hardware output channels 1+2, 2+3 ... 11+12
But only the 1+2 is working. If I select 3+4 and go in total mix, no sound is coming.
I guess i should see something in TotalMix in one of the Software Playback channels.
When I select 1+2 in AUM , the first slot in totalmix get some sound, but if Select the others, nothing is coming in the other slots.
I've tried to change the output in AUM for the metronome, and also directly from the slots output ( with some sound playing of course ! )
It TotalMix preferences, background mode is activated, and Output Channel Count req. is set to multichannel
Maybe i don't understand something ? Maybe I'm doing something wrong ?
Thank you for your help !
