Topic: Totalmix FX - Window won't open (Windows 11)
Issue: When I install the latest madiface drivers (driver_madiface_win_09824) I go through the installation process and it gives me TotalmixFX and the MadifaceUSB applications.
I restart my PC and Totalmix FX doesn't load on startup (it used to a couple of months back).
I try and locate the .exe files to manually run this and I notice it installs the madiface_usb.inf_amd64_.... folder in this directory: C:\Windows\System32\DriverStore\FileRepository
Running the application from here doesnt start TotalMixFX, however it shows in the system tray.
I can right click this icon and load the Workspace Quick Select and that dialog box appears, however getting a new Totalmix Window to appear doesn't work. As a result, I can't get it to connect to the Digiface USB.
I've tried using cc cleaner and uninstalling everything, removing the files from the FileRepository and reinstalling and that doesn't work. I was on Window 7 when the issue started and upgraded to Windows 11 and the issue still persists.
Furthermore, when I started experiencing the problem a few months ago, I fixed this by reinstalling a later version and executing the TotalmixFX.exe in the System32 folder. For some reason, it doesn't load the files in there anymore and loads it in the Driverstore/FileRepo directory.
I've checked out the other forum thread where Totalmix FX wasn't working for first time installation. I've checked if C:\Users\User\AppData\Local\TotalMixFX exists and that does, so can't see an issue there.
Are there any log files I can try send over?
Kind regards,
kalvin104
