Topic: adi2 dac digital to digital or analog to analog
Hi!
It is any possibility to use adi2 dac as a preamp for another analog input signal or to an digital out signal?
I have another dac with an tube buffer output, but without a volume control.
Any possibility to use my adi2 dac as a preamp and use his volume control? I think not because had only digital inputs right?
Another question is if i could use adi2 dac to send digital signal to the other dac?...I do not understand fully how the usb rec coax work or loopback to usb...what signal is rerouted to coax input...analog preamplified one, analog dac level or digital, also to the usb?
The last question, the dsp processing is done to the digital signal before dac or to the analog signal output from dac or after preamp?
It is possible to show me on the board where I could tap the analog signal after DAC and before preamp to send it to the tube buffer that I have or is some trade secret (this to avoid double amplification by op amp and tube?
I am not a person with to much electronic knowledge I just try to resolve this problem that I have.
Thank you!
