Topic: ADI-2 Pro FS R BE as active crossover
This may have been asked before, however, is it possible to use the DSP in a Pro as an active crossover feeding 1/2 and 3/4 to woofers/tweeters of a pair of 2-way speakers, via a pair of stereo power amps?
My understanding is that it probably can be if the low/high pass filter are setup correctly in the DSP.
Has anyone done this or uses this?
Thanks,
David.
RPi4 | RME ADI-2 Pro FS R BE | Senn HD600 | Sugden Masterclass AA | Teddy Pardo i80d | Naim SBL
Re: ADI-2 Pro FS R BE as active crossover
Search function of the forum with "ADI-2 crossover subwoofer" shows plenty entries :
https://forum.rme-audio.de/viewtopic.ph … 89#p187289
https://forum.rme-audio.de/viewtopic.ph … 59#p196859
3 (edited by KaiS 2023-08-19 21:32:06)
ADI-2 Pro and ADI-2/4 Pro SE can be used as basic active 2-way crossover.
The parameters are limited:
• EQ Band1 can be switched to highpass or lowpass and tuned through the complete frequency range.
• EQ Band5 can be switched to lowpass and tuned down to 200 Hz (lower limit).
Can be used to increase steepness of the overall lowpass to 24 dB / Oct.
• 12 dB / Oct. filters only (exception above).
• Q-factor can help to smooth the overlap.
• PEQ can correct irregularities in the bands.
• Polarity of the bands can be inverted.
• Band levels can be adjusted individually, then locked or linked.
• No continuous phase adjustment.
• No delay for the individual outputs.
Further informations can be found in the links @waedi provided.
