Topic: UFX and FF 802 Crackling
Hello
I've recently added a UFX to my FF802 with the idea of expanding the i/o of my setup. I'm running both on USB drivers.
I have an old FF800 connected to my optical inputs on the 802, and the 800 is set to slave and sync'd over ADAT optical. The UFX is connected on a second USB port on my desktop. This is not connected via ADAT or wordclock.
I'm noticing in projects (Cubase 9 DAW running on Win 10) that after a few minutes I'm getting a lot of digital crackling like clocks drifting? This gets worse and worse. If I reset the sample buffer or alter it, it will correct, and then gradually creep back.
I wasn't aware I needed to connect wordclock or something up to the UFX and 802 to get them to play ball, but is that what's required to stop this? I don't understand what's going on?!
Thanks in advance for any help or advice.
