Topic: RayDat ADAT & SPDIF Question
Hi all,
Finally setting up my home studio and have a question regarding my RayDat.
Before connecting everything I’m wondering if the SPDIF & ADAT share channels?
I have 2 Focusrite ADAT expanders locked and running at 96000 Hz (as is the RayDat obviously).
Does using the SPDIF out reduce the available channel count to 14 down from 16 please?
Many thanks.
2 (edited by ramses 2023-09-30 15:44:56)
Re: RayDat ADAT & SPDIF Question
The coaxial SPDIF and AES port are separate / additionally.
The 4th ADAT port can be switched between ADAT and (optical) SPDIF format (see driver settings).
You can read it e.g. at the start of the manual
"2 + 2 + 32 Channels AES / SPDIF / ADAT Interface"
               ^----  4x ADAT = 32 ch
        ^---------- 1x AES = 2 ch
  ^--------------- 1x SPDIF (coax) = 2ch
===> Total: 36 in and 36 out ===> 72.
Webpage tells, 72ch interface .. 2x 36 (in and out) wink
Manual, ch 26, technical details, is also useful, the inputs and outputs are summarized/detailed there:
- AES/EBU
- SPDIF
- ADAT, 4x
Thank you so much, so I have 16 available in/outs plus I can use the SPDIF for a further 2 non-borrowed outputs (in this case to a DAC for monitors left and right)
