Topic: Fireface UFX III
Hi, everyone.
I will be the owner of a brand new Fireface UFX III when it arrives next week. I'm really looking forward to the quality RME brings, as I am upgrading from Focusrite.
With that said, my monitors are Adam Audio S3V and an Adam Sub 12. Currently, I run my output from the Fosusrite to the Sub 12, and then run Satellite Out L + R to each monitor from the Sub 12. I can certainly do that again with the RME, but the Adam's have AES/EBU connections, except for the sub.
Is there any way I can utilize the AES digital connection along with the subwoofer? What I'm assuming I can do is the following:
1. RME AES Out goes to Adam Audio Left AES In
2. Adam Audio Left AES Out to Adam Audio Right AES In
3. RME Analogue Out 1+2 to Adam Sub 12 Analogue Left + Right IN
4. Total Mix - Enable both AES Out and Line Level Outputs 1 + 2
Would that be how to set this up?
Thank you so much for your time.
