Topic: Sample rate mismatch question - connecting RME with Fractal Audio
Hi! I am looking to build a quite complex guitar studio system and have a question on SPDIF/AES connectivity.
So, I have UFX+ as my main audio interface, and I also use ADI-2 PRO FS (via optical channel) and SPL Madison (via MADI) as an expansion. I run it at 96Khz sample rate, which is my main sample rate for working in DAW.
I am looking to buy Fractal Audion Axe-FX III, which only works with 48 Khz. This device has SPDIF and AES/EBU input & output connectors.
I am trying to see if I can connect Axe-FX digitally despite the difference in the sample rates. I recall there were some sample rate conversion capabilities in the RME units, but not sure if they would work fine with this setup, given I also have ADI and Madison hooked up.
Any suggestions would be helpful.
2 (edited by ramses 2023-11-20 20:29:38)
Re: Sample rate mismatch question - connecting RME with Fractal Audio
The ADI-2 Pro has an SRC.
3 (edited by VasilySizov 2023-11-21 01:36:46)
Thank you, I've just checked the manual. Do I get it right, that essentially it decouples input from output, e.g. Fractal Axe-FX III can send 48Khz signal via SPDIF to ADI-2 Pro FS, then ADI-2 Pro FS outputs 96Khz signal to my UFX+ e.g. via AES?
Is it possible to also simultaneously send the 96Khz signal back via UFX+ output to ADI-2 Pro so it gets converted and outputs via SPDIF to Fractal as 48Khz? Apologize if it is a dumb question, but it's not clear from the manual. My guess is I will need the second ADI-2 unit for such backward parallel conversion.
4 (edited by ramses 2023-11-21 07:35:09)
AFAIR SRC works on both directions. Another use case is to use, e.g., a DAT recorder with fix 48 kHz. Try it out.
5
It is clear from the manual. This SRC is one way only. The first application will work. The second only when not simultaneously using the first.
6 (edited by VasilySizov 2023-11-21 16:44:14)
Well, the manual clearly describes a one-way use case, without saying anything about the reverse way in parallel unless I grossly overlooked it.
As you can see, ramses also got it incorrect.
Nevertheless, thank you for the explanation. Perhaps I need something like of one the Mutec units in that case, or the second ADI Pro to make it work.
Sorry, no, because I had no time to look into the manual wink
I only know there is one in, but didn't remember any details because I have currently no use case for it.
Haha no worries, maybe it's just me can't read the manual then :-) Thanks again for all your help, guys.
