Topic: 12Mic-D + DAD AX24 connected via MADI to the RME
12Mic-D + DAD AX24 connected via MADI to the RME:
My 12Mic-D is a slave to my DAD AX24 via worclock. How can I ensure that the DAD is MasterClock in the DANTE controller, given that only the RME is visible there (the DAD via MADI obviously does not appear)?
Thanks for your help !
Re: 12Mic-D + DAD AX24 connected via MADI to the RME
You should make the 12Mic-D "Preferred Leader" in its clock settings. Along with "Sync to external" and MADI selected, that would usually ensure that the DAD remains Master Clock for the entire Dante network. Unless a second preferred leader comes into the network with sync to external active - I believe then you can't make sure.
Ok thanks, that's the answer I was thinking of but wasn't sure. This is my current configuration so everything is ok.
