Topic: Subwoofer on & off via Arc / Totalmix
Hello all,
Sorry if this has been asked before but I did some searching and could not find the right answer.
I am hoping to add a subwoofer to my current setup and would like to be able to bypass it or turn it on and off via the ark USB. I've seen this option before with certain monitor controllers, but I can't quite figure out how to do it without creating different snapshots and having one snapshot EQ to just turn the sub off. However, in that instance it would also remove all the low frequencies from my speakers as well.
Thinking UCX II → Sub → Speakers
Is there a way to add the sub to a different out maybe as a better solution and be able to turn that out on and off with a bottom on the arc maybe?
(FYI passive Amphion speakers and for now I will add a Yamaha HS8S, and then later on possibly larger Amphion speakers with an Amphion sub.)
Thanks very much!
