Topic: Adding MADIface MT
Hi, I have a quick question on the setup of MADIface.
Currently, my system is set up as follows:
1. PC, connected to UFX+ via USB 3.0.
2. UFX+, connected to ADI-6432.
3. ADI-6432 connected to converters, such as ADA-8XR, Lynx Aurora (n), Lucid 88192.
Please note that I am not using TotalMix at all. I am controlling all my mixing functions on Cubase.
On my existing system (1,2 and 3), as I want to increase the number of digital & analog channels, I am about to add one unit of MADIface (to be connected to the PC via USB 3.0) and connect it to the new unit of ADI-6432. So, it will be:
4. PC, to be connected to a new unit of MADIface via USB 3.0.
5. MAIface, to be connected to an additional unit (2nd unit) of ADI-6432
6. ADI-6432 (2nd unit) to be connected to the second unit of Lynx Aurora (n) and other digital reverbs.
So my main objective of adding MADIface is obviously to increase the number of digital & analog channels. And I do not use TotalMix at all so, it does not matter to me whether all the channels are controllable through TotalMix or not. And it does not matter to me whether the additionally added channels through MADIface do not show up on Totalmix or not. All I want to do is to increase the number of channels and control all existing channels & the channels that I am about to add through the mixer of Cubase.
Am I right to say that 4,5,6 will all work fine, with the existing driver that I use for 1,2, and 3? (MADI driver)? So, essentially, would every connection be fine if I just connect MADIface XT and PC via USB 3.0?
Your input will be much appreciated!
Thanks!
