1 (edited by floyd pepper 2024-01-04 15:34:30)
Topic: Digicheck NG
Just installed Digicheck NG on my windows 10.
Cant get it to read my Daw output.
Only the global level meter it has reading, channel 1&2 but not on the spectral analyser and the vector audio scope.
Input selection: Asio MADIface USB. L1 & R2.
Inputs and playbacks both winked/activated.
Only works when i activate loopback on the master channel in Totalmix FX, but i have to really make the volume high to get a decent reading.
Older Digicheck works with same settings.
I'm on windows 10
Fireface UFX ll
Latest drivers
buy the ticket take the ride..
Re: Digicheck NG
Do i need to uninstall the old Digicheck perhaps?
3
Re: Digicheck NG
You are aware that you need to configure the display source for every instrument separately? If it works on one then it will work on the others as well when configured correctly.
You cannot 'activate' inputs and playbacks with those checkboxes. This is only a mask for the list to make it easier to navigate. You need to select the correct input channels in the table.
Re: Digicheck NG
thank you for the reply MC
yes i saw that i have to configure the spectral analyser and the vector audio scope separately.
both are set to playback like the older digicheck that works with the same input selection.
and in the table i have only one option Audio device 1 - in use - ASIO MADIface USB - set actively.
2/3 not assigned.
still no luck and im really trying all option here, its always that one last overlooked thing hey smile
Re: Digicheck NG
just to be clear, you meant 'configure the display source' that i have to stand in the spectral analyser and/or the vector audio scope window and right click and select 'input selection', then select audio device and playbacks?
that's what i did on both windows/fields.
6
Re: Digicheck NG
Can you upload a screenshot of that dialog?
7 (edited by floyd pepper 2024-01-05 19:21:02)
Re: Digicheck NG
Did not know how to upload the 2 screenshots here so..
its a little out of the box but just to make sure, added them as pictures
https://soundcloud.com/romaxbeirut/cowbell
https://soundcloud.com/romaxbeirut/swit … l-cowbells
8
Re: Digicheck NG
https://forum.rme-audio.de/viewtopic.php?id=29217
Re: Digicheck NG
hey mc
i searched here on the forum and saw that topic thanks.
unfortunately the tool page doesn't open for me for some reason but my links will take you directly to the screenshots.
sorry for unconventional approach  wink
Re: Digicheck NG
floyd pepper wrote:
hey mc
Pictures via links to soundcloud? Looks to me more like someone wanted to generate clicks on his profile?
roll
“Do It For Her”
11 (edited by floyd pepper 2024-01-07 15:36:51)
Re: Digicheck NG
maggie33 wrote:
floyd pepper wrote:
hey mc
roll
Your comment is a bit silly tbh, generate clicks on technical Rme forum on a post that i created, what is the max reach of that..
I'm not a desperate musician.
wisely you could have chosen to help me, perhaps you can tell me if there is a easy way to add 2 screenshots to the rme forum?
12 (edited by ramses 2024-01-07 16:51:19)
Re: Digicheck NG
floyd pepper wrote:
i'm not that desperate, but i understand you.
perhaps you can help tell me if there is a easy way to add 2 screenshots to the rme forum?
Short story: place image to a cloud provider of your choice (*) and post the URL to the picture included into image tags.
Longer explanation with a more detail and background information
https://www.tonstudio-forum.de/blog/Ent … rum-EN-DE/
(*) some cloud provider do not support that the forum can read and display the picture directly when accessing the URL.
Your two images here, deleted the rest so that everybody has a better overview:
https://www.dropbox.com/scl/fi/h0nztenu9g4xlqs5lyhrc/1.PNG?rlkey=hn0ts7mv1lei5bgvipq21pro2&dl=1
https://www.dropbox.com/scl/fi/qv2qxiw9f677v21p843aa/2.PNG?rlkey=i8k1b85l4brfi1klu6j4d0a3u&dl=1
13 (edited by floyd pepper 2024-01-07 15:39:39)
Re: Digicheck NG
(*) some cloud provider do not support that the forum can read and display the picture directly when reading this thread. Also explained with example in the blog article.
thanks a lot, i have dropbox that i never use nut here goes, i hope it works:
https://www.dropbox.com/scl/fi/h0nztenu … 2&dl=0
https://www.dropbox.com/scl/fi/qv2qxiw9 … u&dl=0
would be so kind if you could check, when i click on them they don't work, go figure..(slightly annoyed wink
Re: Digicheck NG
thanks again..
i tried the img before the url but got a warning.
Warning! The following errors must be corrected before your message can be posted:
url was opened within img, this is not allowed
i will leave it for now, at least MC can see the screenshots, again thank you for checking them at least now i can remove those cowbell samples from my soundcloud page wink
15
Re: Digicheck NG
I told you to select the correct channels. Position your mouse on the 'Analog 1' entry and click it, then select the 'Playback Analog x' channel from the long dropdown list.
Re: Digicheck NG
thank you mc, they showed in bold so it seemed they were already selected to me.
they are correctly selected now, thank you for your time!
