1 (edited by Thermaltake 2024-01-09 20:11:56)
Topic: [Solved]UCX II not showing output or input with driver 1.249
Win 10 latest updates and all that.
Flashed latest firmware for ROOM EQ on my UCX II (successfully) turn it off and on again, and then install latest drivers(Run as Admin.), but no sound source in sound, I can't get sound to work now. In device manager everything is fine. USB is connected. Help...
https://i.ibb.co/QnVrSJK/1.jpg
2 (edited by Thermaltake 2024-01-09 20:29:27)
Re: [Solved]UCX II not showing output or input with driver 1.249
Tried on laptop, same thing...is my UCX II now faulty... and I'm just out of warranty. sad
(Cold) reboot doesn’t help?
4 (edited by Thermaltake 2024-01-09 20:47:14)
Nop, tried to shutdown UCX II and PC, disconnect the adapter from outlet for minute, and plug it in still nothing.
Like I said tried on laptop same thing, it won't see outputs or inputs anymore sad
I flashed all kinds of RME cards for years now, and never had any problem, until now.
1) What about ASIO applications? Can they access the interface?
2) Are you sure you have WDM devices configured properly in driver's control panel?
6 (edited by Thermaltake 2024-01-09 22:00:06)
1. Cubase is seeing it
2. Oh damn after reinstall it was set on 0 by default... now I set it to 10. It's okay now everything is like it should be big_smile Thanks!
