Topic: ADI-2 FS - Headphone out and XLR outputs, Mute XLR?
Hi
I have the ADI-2 FS in for a tryout.
Is there a way to mute the main outputs and just listen using the headphone output?
I have read the section 6.4 in the manual [Variable Output Level] -- and this seems to make some volume adjustments there, but not mute the Main outs totally, and just hearing the headphone output.
Can this be done in total mix?
- Leon
2 (edited by waedi 2024-01-11 00:38:33)
Re: ADI-2 FS - Headphone out and XLR outputs, Mute XLR?
Totalmix is not available for this unit.
Searching the user manual for "mute" reveals one hit :
Mute relays on XLR and Phones Out...
Unfortunately no further instructions how to mute.
The user manual may need an update for your topic.
This is very rare.
The ADI-2 FS does not have this option and does not support TotalMix.
A switched power strip could power down the speakers when listening to headphones.
Alternatively an analog audio switch could do the job and might even extended the monitor capabilities.
https://www.amazon.de/Nobsound-Switcher … 3&th=1
https://m.media-amazon.com/images/I/31ObS6Xp2YL._AC_.jpg
https://m.media-amazon.com/images/I/719KRP3zmdL._AC_SX679_.jpg
Hi KaiS
Thanks for the info, and the way to control the monitor.
I do like the sound of the ADI-2 FS - and the only hangup is turning of the mains monitors as needed, so a switch would probably do the trick.
Best Regards,
- Leon
5 (edited by KaiS 2024-01-11 08:32:58)
The Mackie Big Knob Passive could be a good solution too.
• Big Knob feed with fixed level from ADI-2 FS (manual page 7), to control the monitors.
• ADI-2 FS’s volume control set to independently control headphones level.
https://thumbs.static-thomann.de/thumb/padthumb600x600/pics/bdb/_40/407242/12224942_800.jpg
Or there is remote a controlled powerstripe. I use it as I do not want co crawl below the desk.... It is called PowerCube.
https://www.google.com/search?sca_esv=5 … &dpr=1
