Topic: [Solved] Digicheck NG 0.90 - Lost Playback Channels
Hey All,
I updated the driver and flash update for the UFX+  total mix v1.93 and now do not have the option to add playback channels in Digicheck NG. it was working before i updated Total Mix and the UFX+.  I have re installed DIGICHECK and the problem persists. Any thoughts?
Thanks Much
2 (edited by waedi 2024-01-31 01:09:29)
Re: [Solved] Digicheck NG 0.90 - Lost Playback Channels
In Digicheck Options Audio Device Setup there is the feature enabled ? "add playback channels" ?
I use the same Totalmix version (1.93) and the same Digicheck NG version (0.90) and the playback channels working fine.
It is not the UFX+ here, only a Digiface USB.
the option for the playback channels is greyed out. no ability to change the status.
The UFX+ has the latest firmware on ?
5
Which driver is used here? Just checked with 4.10, works.
I believe it is the latest driver... i am using Room EQ
Update. i thought that i was on driver 4.10.... i guess i was not, though i know that i had updated to be able to use the new room EQ + crossfeed features.  i reinstalled the driver and playback channels work... again
thanks much
