Topic: Clock synchronization: UFX III connected to M-16 DA
I am considering to use UFX III connected to M-16 DA for OTB mixing.
The data flow would be then:
DAW channels (out) --> UFX III --> MADI optical connection --> M-16 DA --> Analog Summing --> back to UFX analog input.
What is the recommended clocking solution? Is it more convenient to select MADI in the M-16 DA Clock Section, or to connect UFX WCK Out to M-16 WCK In, and then select WCK in the M-16 Clock Section?
Or, as an alternative, to set M-16 as master clock and UFX as slave?
Thanks for advice.
