Topic: TotalMix in Direct Monitoring mode with Cubase
using RME UFX with Cubase 12 in Direct Monitoring mode for recording
problem:
i set the monitoring volume in TotalMix via the channel fader in C12 for a good volume in relation to the track playback for an overdub.
(note; when i set the C12 fader to unity the TotalMix fader is set to +5db...?)
when i then want to listen to the just recorded track the playback volume is different/louder than it was during the Direct Monitoring by about 6db.
so i have to pull back the fader to listen. but then for the next recording pass i have to put it up again... etc.
i would like to achieve that switching between Direct Monitor and playback of the same track there is no difference in volume (like in the old analog days...)
any ideas?
thanks
