1 (edited by decemberance 2024-02-10 01:47:06)
Topic: How to route sound from total mix to bluetooth headphones in win 10
I want to listen my mix  from my DAW in a bluetooth headphone (for comparison) in windows 10.
I cannot find a solution, is it possible?
Thank you for your time.
RME UFX - Windows 10 Pro
Re: How to route sound from total mix to bluetooth headphones in win 10
Not possible as the bluetooth headphone acts as an audio interface for the computer and replaces your other interface.
In Windows you can't have both active.
In the DAW you have to select the audio device your bluetooth headphone but then Totalmix is off.
3
These are standard Windows procedures.
- Make sure you have at least 1 WDM devcice activated in the UFX Settings dialog
- Open Windows Sound panel, tab Record, select the UFX WDM input device, button down right Properties
- Tab Monitor, check 'use this device as playback source'
- Select your BlueTooth phones as playback target (all these names and text in these dialogs are horribly wrong in German, totally confusing)
- In TotalMix FX hit Loopback on the output channel that equals the WDM device. Make sure your mix is sent there.
Voila. This setup/setting works with everything. It uses Windows own mixer for rerouting a record signal to any playback device.
All Windows names/lables might be a bit different (I just tried to translate the German ones).
Thank you very much , I will try it  now!!!!
- Open Windows Sound panel, tab ecord, select the UFX WDM input device, button down right Properties
- Tab Monitor, check 'use this device as plaback source'
Yes it worked!!!!!!
Thank you very much!!!!!!!
