decemberance wrote:I want to listen my mix from my DAW in a bluetooth headphone (for comparison) in windows 10.
I cannot find a solution, is it possible?
RME UFX - Windows 10 Pro
These are standard Windows procedures.
- Make sure you have at least 1 WDM devcice activated in the UFX Settings dialog
- Open Windows Sound panel, tab Record, select the UFX WDM input device, button down right Properties
- Tab Monitor, check 'use this device as playback source'
- Select your BlueTooth phones as playback target (all these names and text in these dialogs are horribly wrong in German, totally confusing)
- In TotalMix FX hit Loopback on the output channel that equals the WDM device. Make sure your mix is sent there.
Voila. This setup/setting works with everything. It uses Windows own mixer for rerouting a record signal to any playback device.
All Windows names/lables might be a bit different (I just tried to translate the German ones).
