BasariStudios wrote:Thank You, so in other words there is no difference at all.
This I didn't say Again, what I mean … You can use my blog article comparing "UFX vs UFX+"
for your goal to compare "UFX with UFX II" because UFX+ and UFX II are so close to each other.
There were many enhancements between UFX and UFX+/UFX II, and this is summarized in the blog article.
And now the distance between UFX and UFX II became even bigger because the UFX II got the following enhancements from UFX III:
- got the analogue board of the UFX III (slightly improved technical specs and with converters from ADI-2 Pro FS)
- got enhanced digital section ("triple SPDIF"); AES and both ADAT ports work independent of each other
- both ADAT ports can be switched to optical SPDIF
- UFX II and UFX III can get the new room EQ and Crossfeed (UFX doesn't have FPGA resources left for that)
https://forum.rme-audio.de/viewtopic.ph … 06#p212706
If you have the budget, get UFX III, more headroom for expansions.
It is also beneficial to be able to use some of the MADI ports for creating interesing submixes and for loopback recording.
