Topic: ADI-2/4 PRO SE in Stereo 2.1 Channel Setup
I was streaming music from my iPad through an ADI-2 DAC FS, utilizing the USB as the source and the XLR outputs for connection to a 2-channel power amplifier that drives my left and right floor speakers. The system was further enhanced by adding an SVS SB-1000 powered subwoofer, linked through the left and right RCA analog outputs of the ADI-2 DAC FS. This setup allowed for the subwoofer's filtering and DSP to complement the DAC's PEQ settings, effectively smoothing out a sound null by 15-20dB and significantly improving the audio quality.
After upgrading to an ADI-2/4 PRO SE, mainly for the Pentaconn connector for my Dan Clark Audio Stealth headphones, I faced a connectivity challenge. The new DAC uses 1/4" sockets instead of the RCA connectors, and I currently do not have the required cables to connect my subwoofer. This came after I had decided to declutter by discarding a collection of old audio and video cables.
I am contemplating using the PH 3/4 connection for the subwoofer and potentially adjusting the DAC's PEQ for channels 1/2 for the floor speakers and 3/4 for the subwoofer. However, this might be less than ideal due to the cables protruding from the front, especially when considering the occasional use of the 4.4mm headphone connector. My preference is to replicate the previous setup, and since I have retained the PEQ settings, reinstating the original configuration should be straightforward.
I am seeking advice on the best course of action. Do I need to purchase a few mono 1/4" to RCA cables to connect the 2/4 PRO SE to my subwoofer, or is there a more optimal solution with my existing equipment? Is there a simpler alternative that I might be overlooking?
Thanks in advance and sorry if this is old news again. I just read the entire manual online and I went page by page of this forum reading any topic that had the word "sub" in it through the first 15 pages or so, and I did not find anything specific to ease my mind and solve my questions; though, I am not the brightest bulb in the chandelier.
