Topic: Babyface Pro FS Headphone, pop results in no sound on one side
I am having an issue with my BFP fs where I pick up my Audeze LCD-X headphones and I can hear a pop occur, then there is no sound on one side of the headphone until I power cycle the interface. Monitors play fine, both headphone ports are affected by the issue when it occurs.
This issue does not happen on 4 of my other systems when using this same headphone. Nor does it happen with other headphones on this interface. Tested dt 990 pro 250 ohm, hd 598, HD 25 HD 280 pro and EL-8. I have changed the cable on the LCD-x to check, it's not the cable.
When I play audio Digicheck shows both sides of the headphone are receiving output. The issue has been occurring for over a year.
I have purchased a power supply for the BFP to see if it would mitigate the issue but it has not helped.
I am using the included usb cable. I have tried other usb cables, other usb ports (Directly in to the motherboard), 2 usb hubs.
I have reached out to the RME support team but have not had any success in locating the issue and was referred to my retail location. Local retail location where the unit was purchased from told me that my warranty period has passed and I would need to come into the store and replicate the issue on the showroom floor for them to consider taking a further look into it.
Ps. I dont think request to bring in my pc tower, interface and headphone for a lan party on the showroom floor is a reasonable ask.
As the issue does not happen every time I put the headphone on the table and pick them back up.
I have not tried using another computer with the interface to replicate the issue.
I have not sent the headphone for servicing or inspection to audeze but no issues when using other devices.
