Topic: Is it okay to connect Korg Minilogue XD to inputs 3 and 4
Is it okay to connect my Korg Minilogue XD to inputs 3 and 4 on my Babyface PRO? The manual says these inputs have high impedance, so I'm using the Gain knob in Total Mix to boost the signal. Does this affect the sound quality? Should I buy different cables and connect the synth to the inputs on the back panel instead?
Thanks in advance.
2 (edited by oli77sch 2024-03-08 12:23:44)
Re: Is it okay to connect Korg Minilogue XD to inputs 3 and 4
Hi
Inputs 3/4 are fine for line level signals. Both Korg outputs and Babyface pro inputs are unbalanced, so that matches.
Thanks. Does the fact that I have to amplify the signal using the Gain button (in Total Mix) affect the sound quality?
oli77sch wrote:
Hi
4 (edited by waedi 2024-03-08 16:00:41)
No
Did you try max output on the Minilog and no input gain in Totalmix ?
Should be fine.
I turned the Master knob on Korg to the maximum. And then the RMS reaches -24db in Ableton Live. Then I amplify the signal by 7 db using the Gain knob on TotalMix and then the signal becomes acceptably loud. Around -12 db. The audio sounds okay to me, but I'm not sure if I'm doing this the right way.
No
Should be fine.
To what level are the Babyface inputs set? -10dBV or +4dBu?
+4dBu
8 (edited by oli77sch 2024-03-08 20:26:52)
With -10dBV you would get a bit hotter signal and another step up you go with 'boost'.
wow! It works much better now! Thank you
Glad to hear! Anyway, I wonder about the low output of the Minilogue.
