Topic: Advice on upgrade from SLL Alpha Link/HDSPe to RME Converter/Interface
Hello All,
Longtime RME user, first time poster.
I need some advice on either upgrading or augmenting my current set up.
My desire is to upgrade my conversion (and latency) if possible, and still interface all my outboard gear.
My current setup is a SSL Alpha link Madi SX into an original rev 1 HDSPe. That combo has been rock solid and trouble free for well over a decade.
The SSL interfaces an original Octa Mic and 4 Vintech pres, along with a Bricasti, Evenetide, TC electronic M3000, API 2500 and 5500 and A Designs Hammer before running into a 2400 Audio Imperium monitor controller.
At the time - the SSL was a godsend with the all the analogue and AES i/o, though I have always been suspect of the conversion. (it may be in my head, but it does seem somewhat odd to me in comparison to other converters I have used over the years)
The original rev 1 as you all know, does not allow the Total Mix FX when tracking vocals. That along with the SSL's lessened track/channel count at higher sample rates is why I am considering an upgrade/augment.
My questions are:
Could the UFX 3 replace the SSL (and the original HDSPe) as far as connecting all the out board gear, and give me a little room to grow if I acquire more outboard. And is the conversion on the 3 noticeably better than the SSL?
I assume it is, but these things can be subjective to the point of silliness. Like everyone, I would like the best converters I can afford. Though I don't want to fall victim to my own internal gear acquisition syndrome if splitting hairs is the final result.
Or would I better off getting the ADI pro 2 FS R BE for the conversion to my monitors and keeping the SSL to interface the outboard gear?
Or ... is there a better RME solution to streamline my rig that would allow improved conversion, (and latency) all still allow me to get all my outboard interfaced that I am overlooking?
Any advice, insights, or general comments are greatly appreciated. I am still learning and just reading the forum has been a great help.
Thanks to all in advance.
