conor wrote:Having a routing problem
My headphones are plugged into 3/4 on the front
But i can only hear through the headphones when 1/2 is selected in wavelab, not 3/4 (silence)
Multichannel mode is on
Any ideas?
Also i can't seem to send a signal to the hardware chain, due to this same issue (1/2 into gear, 1/2 back from gear, 3/4 monitor playback)
Thank you!
One new thing in the ADI-2/4 Pro SE's design is that the rear TRS outputs can be assigned to channels 3/4 as independent 2nd line output / play out path.
You need to find the setting, to assign outputs 3/4 again to the phones outputs in the front.
Check the manual, maybe you start looking at the block diagrams of the different routing modes.
I do not know from memory in what chapter this information is in, but should be no rocket science after my explanation with what this has to deal with.
A good chance to become acquainted with the manual
Or maybe you find it "intuitively" using the ADI-2 Remote application.. Store the current settings to a user profile to be able to come back to this state well and then ... clickediclick(tm) ...
waedi wrote:You have to use Totalmix and route the desired channels to the headphone, pull up the second fader in the middle row when the headphone output Phones1 is selected (click into it)
RME ADI-2/4 PRO SE is a reference converter and does not have TotalMix FX.
