Topic: Remonte Controle pour ADI 2 DAC FS
I did the update. The MIDI control option is activated via the RME setup, but the ADI 2 Remonte ADI24 Pro app is disconnected.
What do I need to do to establish a connection between the app and the RME?
The advantage of this app is that you can fine-tune the EQ settings from your sofa while listening to the music (if I've understood correctly).
LINN AKURATE DS, LINN UNIDISC SC,AMPLIS MCINTOSH C300 et MC7106 + RME
2 (edited by KaiS 2024-04-23 22:11:48)
Re: Remonte Controle pour ADI 2 DAC FS
• Restart ADI-2 after the update.
• USB connection from PC / iPad with ADI-2 Remote app, to ADI-2?
• Try a different, short USB cable.
I'm going to try with a short cable, but in this case I have to be 50cm from the RME, the REMONTE loses its interest. impossible to play with the EQ from my sofa between my speakers?
i bought a short 80 cm cable and it still doesn't work. my PC is running Windows 11. is it compatible with your application?
What firmware number is shown when you start ADI-2 DAC?
62
ericcholley63 wrote:
62
The latest.
Could you test another computer?
I can try, I'll contact you as soon as it's done.
can the firewall block the application?
I tried it with a PC windows 10 cable length 5 meters and it works fine.
what's wrong with mine?
  1. Which operating system is running on your PC?
  2. Which build?
  3. If it is Windows: Which version of MADIFace is installed?
  4. USB connected directly or via a hub / docking station / ...?
Ralf
(ADI-2 Pro FS with ThinkPad Yoga L13, Dynaudio Focus 600 XD or Focal Clear — and a lot of Jazz)
11 (edited by ramses 2024-04-24 15:44:07)
You need besides latest firmware also MADIface driver, please read the prerequisites, e.g., here:
https://forum.rme-audio.de/viewtopic.php?id=38074
All working fine here with MADIface driver 0.9833.
Regarding cable length, up to 5m for USB2 according to standards ..
https://www.dropbox.com/scl/fi/j04u7gxvuknd8tqkjaud4/2024-04-24-Downloads-ADI-2-Remote.jpg?rlkey=jkinh9hstfjyri3i0ile5zjqb&dl=1
on the second pc windows 10, 32 bits (lent by my wife)
cable connected to USB input
Madiface not installed on this PC
Immediate connection with Remonte and RME (great app)
my PC: Windows 11, 64 bits
Madiface from 03/2023
same cable connected to USB input and still "ADI-2 Remonte ADI-24 Pro Disconneced".
As you see in my posting RME has a certain requirement for minimum release of MADIface driver.
So you should tell which _version_ of MADIface driver you have installed, not a date ...
New revision: USB78,DSP 51
Current USB revision: 81
DSP firmware version: 62
Fallback USB revision: 34
with previous version same result "Disconnected, with this new version same "diconnected".
New revision: USB81,DSP 62
Current USB revision: 78
He asked for http://www.rawac.de/bilder/RME/driver_version.jpg
Ralf
As I assume you didn't do this yet, please install the latest MADIface driver and reboot your computer afterwards.
https://rme-audio.de/downloads/driver_m … _09833.zip
I installed the latest Madiface driver and...
It works. Thanks for your patience and have a nice evening
