Topic: ADI-642 not sending good signal at 44.1
I have this weird problem. My DAC (dCS Debussy) is able to lock when ADI-642 sends AES out at 48k but not at 44.1k. When set at 44.1k, DAC continuously tries to lock and produces the clocking-locking sound continuously at very high speed.
My setup is as follows.
Win 10 Computer > MADIFace USB > Fiber optic cable > ADI-642 > AES out > DAC
I did my diagnosis and my conclusion is that something is wrong with ADI-642 because -
a. It produces the locking-clicking sound continuously even after my computer and MADIFace USB is off.
b. I fed my DAC with another 44.1k source and it is able to lock and play the music.
Any help/insight would be a great help.
Re: ADI-642 not sending good signal at 44.1
What sample rate is the Madiface set ? Try different
As I mentioned earlier, the problem occurs even when MADIFace USB is off. But when I run it, it is set at 44.1.
With 48k, everything runs smooth.
4 (edited by waedi 2024-05-25 06:30:54)
But you didn't mention how the clock settings are in the Madiface.
And at the ADI642 front panel what is selected for clock ?
5
The ADI-642 settings are the only relevant info here.
6 (edited by hifimckinney 2024-05-25 15:00:37)
On ADI-642, when I choose 44.1, DAC cannot lock the signal however; I can hear music coming out of headphones out of ADI-642 but the DAC is not able to lock. But when I set to 48k, DAC can lock.
Please note that I understand that frequency must be same all across. This arrangement has been working for years, the problem started occurring recently.
7
The 642 gets the signal from MADI and should be slave to the MADIface USB. So in the Clock section it must be set to MADI input - no sample rate, and also not DS/QS.
