1 (edited by Monk303 2024-05-26 17:05:02)
Topic: Ucx ll noise
good afternoon, tell me, has anyone encountered the cause of this level of noise? I can't hear it, but I can only see it on the mixer.
Screen
https://dropmefiles.com/7xAEZ
did the following:
1. Switched to other inputs of the audio interface (rme ucx ll), where I connect my other instruments - nothing
2. I took all the connections, wires, etc. and connected it to the same inputs where the noise level on my other instruments is fine - it didn’t help... nothing, as soon as I connect this synthesizer, noise immediately appears. in these channels.
3. I took and replaced two different power supplies, the original one - also nothing.
4. I connected it to another outlet and took it out, oops - no result.
5. I connected to babyface pro fs - the problem did not go away.
Does anyone know what I should watch? I will be grateful for your help! Thank you.
2 (edited by waedi 2024-05-26 15:24:14)
Re: Ucx ll noise
The instrument setting in the Totalmix inputs is not for synths, those are typically line level, what is your synth?
Switch off Inst in the input channel.
3 (edited by Monk303 2024-05-26 17:05:35)
Re: Ucx ll noise
Thanks for the answer! I forgot to mention this right away!, but My synthesizer is connected only to channel 7/8 and there is no high-impedance connection on it!
Screen
Re: Ucx ll noise
Hello
I guess you've connected your synth using 2 TS cables (Mono) to UCX II 7/8 inputs, right?
And is your synth also connected via USB? If yes, any difference when you disconnect the USB cable?
UCX II FW106/34/104 v1.253 TM1.97 - PC Win11 23H2 / Fedora WS 41 - Reaper 7.27
Re: Ucx ll noise
A Full Reset in TotalMix always helped solve any (user related) issues with my UCX-II.
6 (edited by ramses 2024-05-27 06:27:52)
Re: Ucx ll noise
Alternatively, save your proven configs into a workspace file and recover by loading it.
Additionally I recommend to save the workspace into one of the Quick Workspace Select Slots.
Best to use the Slot 1..8, because then you can recover those quickly using ALT-1 .. ALT-8.
Whenever I try something for somebody on forum, I can recover quick and reliably by pressing ALT-1 in TM FX.
