Topic: Ucx ll noise
good afternoon, tell me, has anyone encountered the cause of this level of noise? I can't hear it, but I can only see it on the mixer.
Screen
https://dropmefiles.com/7xAEZ
did the following:
1. Switched to other inputs of the audio interface (rme ucx ll), where I connect my other instruments - nothing
2. I took all the connections, wires, etc. and connected it to the same inputs where the noise level on my other instruments is fine - it didn’t help... nothing, as soon as I connect this synthesizer, noise immediately appears. in these channels.
3. I took and replaced two different power supplies, the original one - also nothing.
4. I connected it to another outlet and took it out, oops - no result.
5. I connected to babyface pro fs - the problem did not go away.
Does anyone know what I should watch? I will be grateful for your help! Thank you.
