Topic: Issue with Digiface USB and Ferrofish Pulse 16 at 44khz
Software: Cakewalk Sonar
OS: Windows 7
Digiface USB/Ferrofish Pulse 16
I'm a complete newbie to the forum, and to the Digiface and Ferrofish. Most of my projects are recorded at 96/24, but I do work occasionally with 44/24 legacy projects from other musicians. I am having an issue where, at 44kHz, I am only getting the right channel from Sonar's master bus.
At 96kHz, everything seems to work as expected, I get stereo output from Sonar's master bus sent to the Ferrofish's hardware outputs 15 and 16, which connect to my powered speakers. But at 44kHz, I only hear audio in the right speaker. The Ferrofish shows stereo output on channels 31/32 (hardware channel 16), but I only hear output in the right speaker. I have headphones connected to the Digiface headphone out, and I hear both channels in the headphones.
If I switch back to a 96kHz project, everything works as expected, but switching back to the 44kHz project it does not, still no output in the left speaker. I have been to the matrix view in TotalMix, everything seems set up correctly there.
What am I missing? this has to be some sort of virtual to physical routing issue, but I cannot find anything out of place.
Thanks in advance for reading, and for sharing any input that you might have.
Paul Cooper
