Topic: Increased latency with AES converter = normal?
Not sure where to post this as it isn't strictly about my RME MADIFace Pro!
I've just upgraded my AD part of my ADDA master chain from the standard outputs of an SSL Alphalink SX, to a Lavry Black AD10. I've been using a DA10 for monitoring years and my plan was to get another DA10 or DA11 (or Benchmark) to have a 'poor mans high end' ADDA for mastering or master bus duties (or 2008's finest).
However, after adding the AD10 (connected to SSL Alphalink SX via AES) the round trip latency in Logic went from about 62 samples (with just the Alphalink DA to AD roundtrip) to 240 samples when using the AD10.
Anyone have a clue why the latency is 4x higher now? Is this normal for the Lavry/an AES connection?
The clock is set to AES, as is the Alphalink. I have an RME MADIFace Pro as the main USB audio interface/brain, using its internal clock. I've experimented with different clock sources, it made no difference.
Am I doing something wrong? (I hope so)
Thanks!
