Topic: sync problem with ADI-8 DS
Ok, so I need help.
I suddenly found a few days ago that I get "clock-like" clicks from my inputs on my ADI-8 DS when running signals into it. They occur consistantly every second or so. It does not occur during playback, so I figure it's on the the A/D-side of things. It is only present when inputs are active. If I turn off gear going in the "front" it goes away.
I use the ADI-8 DS to convert signals from my pre-amps, route to hardware inserts etc.. I've also noticed that the 'SYNC' light is off.
Clock is set to input both ways. It runs in and out of a Madiface USB via ADAT.
The Madiface USB shows 'SYNC' in the control panel and has it's clock set to internal and the problem is not present with my Focusrite Clarett Octorpre, which is set up the same way as the ADI in terms of clocking from Madiface, obviously. Despite this I've flashed the Madiface and updated the driver - no joy.
Apart from swapping the ADAT cables, I think I've gone through and checked everything. I fear the actual hardware is failing.
Has anyone experienced anything similar and found a solution?
Thanks for any replies and best regards
