Topic: [Solved] UCXII display issue
Hi there!
A few days ago I bought an RME UCXII interface. When I turned on the first time, the display worked fine, but after I installed the new firmware the display only lighting in white and nothing happens. Is it possible somehow to get the previous firmware to check if it occurs the problem? I contacted the distributor, but they cannot change the item, 'cause it is not a factory error.
