Topic: [Solved] Dgiface usb connecting to jriver
Hi
I have am running a test signal into jriver wdm via digiface usb to measure speaker convolution filter
I can get tidal etc. to play on jriver wdm and on windows sound settings for recording it shows a signal in but not on jriver playback
The ipc is activated on jriver and a connection to merging happi dac flashes up when started but there is no sound
I have digiface set as straight payback and it shows signal on input adat and main
the annoying thing is I have had this working a long time ago and cant get it now
Its almost like a volume setting but I have everything at 100%
any advice appreciated
thanks
Phil
