Topic: Feedback and no audio from software
So I had a setup for my podcast where my main mic was connected to a preamp which went into the Fireface UCX 2 via ADAT.
I've since moved that mic to the mic 1 (analog 1) input on the front of the Fireface.
Ever since then I'm having the following issues and neither my wife nor I could figure it out.
1. Main mic (mic 1) is feeding back in the DAW (Reaper). Does this have to do with the mic being on analog 1 while main out is analog 1/2?
2. Separate track for audio clips that I lay in in real time is not getting any audio now from the program (Farrago).
I'm not going to move the mic back to the ADAT connection so how do I make this setup work for my podcast?
Would greatly appreciate someone helping me out here.
M1 Mac Mini (2020)
Fireface UCX 2
2 (edited by waedi 2024-07-05 19:54:45)
Re: Feedback and no audio from software
The main out analog 1/2 is connected to loudspeakers ?
And the mic is in the proximity of those speakers ?
You may use a headphone for the podcast instead of loudspeakers.
Also make sure not to send mic input signal directly to the main out in Totalmix.
In Reaper switch off input monitoring, the I-button next to the R-button.
The signal from Farrago appears in Totalmix in the Software playback channels 1/2, from there you have to route it to the desired output.
I do have speakers connected but they are potted down. They’re connected to the headphone amp (fed by fireface headphone).
How do I make sure the mic input signal isn’t feeding the main out?
M1 Mac Mini (2020)
Fireface UCX 2
In Totalmix click onto the main-out channel. It gets highlighted.
Pull down the fader of the mic input channel.
In Reaper switch off input monitoring on the track where the mic signal is.
I've got the feedback sorted out.
A couple questions though.
1. Am I able to monitor in Reaper with the mic in analog 1?
2. Not hearing the mic that's in analog 2 (babyface ucx 2).  There's level going into the DAW but I'm not hearing it at all until playback in DAW.
M1 Mac Mini (2020)
Fireface UCX 2
In Reaper is input monitoring ON ?
https://i.ibb.co/st0mBPd/monitoring.jpg
yeah. it was on. Mic 2 seems to be okay now.
M1 Mac Mini (2020)
Fireface UCX 2
How do I set it so I can monitor in reaper without feedback?
M1 Mac Mini (2020)
Fireface UCX 2
In Totalmix route software playback channels 1/2 (where your signal from Reaper is) to the speakers only, no other channels sending to the speakers.
route here?
https://i.imgur.com/R4Q3yZ7.jpeg
M1 Mac Mini (2020)
Fireface UCX 2
11 (edited by waedi 2024-07-12 17:57:51)
Yes if this is your speaker.
But this not how to route.
Click onto the hardware output channel Phones 1 (where your headphone is)
and pull down all faders of hardware input channels and software playback channels except the software playback channel Analog 1/2.
Then you are sure only the software playback 1/2 is routed to the headphone.
If feedback still persist then in Reaper is to block a signal.
