1 (edited by tofer76 2024-07-11 12:50:28)
Topic: [Solved] Proper connection of Digiface Dante - latency
Good afternoon, friends! I ask for help connecting digiface dante to macbook pro 2019 i9. It only has four usb type c connectors. Which adapter will work correctly? Who uses which one? I use live professor and latensy are critical for me.Thank you.
Re: [Solved] Proper connection of Digiface Dante - latency
A regular USB cable USB-B to USB-C
https://www.digitec.ch/im/productimages/5/1/4/1/6/7/1/8/3/8/4/6/9/8/9/7/9/5/7/a5e64c45-8a99-4c0c-8683-cee708b917fd_cropped.jpg
any as from printer USB-B to USB-C 3.0? The link in your post doesn't work
4 (edited by waedi 2024-07-11 13:42:06)
Yes exactly, sorry for the non-working link, here again from a screenshot :
To be exact : USB cable type B 3.0 to type C 3.0
https://i.ibb.co/vDbPTBM/Bildschirmfoto-2024-07-11-um-14-30-52.png
Thank you very much for the advice. I will be looking for such a cable. I tried several adapters with a native cable, but the latency is too high (8 ms). Thanks again for your time
I seriously doubt this will help with the latency. If there were usb errors, then yes. But to little info to assist with the latency issue.
the problem is that when connecting the card to an old mac mini mid 2011 computer with a wire from the box via usb, the latensy in live professor is only 1 ms at the input and 1 ms at the output.When connected to a new macbook pro latensy 3ms in 3ms out
That is the right question! Sorry that this is not my expertise (mac) but I am sure someone will try to help. Are the audio settings the same? AFAIK you set latency there, buffer size.Or are you talking about another latency?
Depends on the MacOS. What OS is on the old macMini ?
Have you connected any Dante device with input channels ?
May be only two output channels was actively used in the system as it states 1ms output latency.
10 (edited by tofer76 2024-07-12 05:10:22)
On an old mac mini, there is a High Sierra.On the new Ventura.The buffer size on both is 128 samples. The liveprofessor uses all 64 input and output channels.I'll take a photo and post it a little later
On the old Mac the driver is the 3223, right ?
On the new mac is the 410 driver ?
This would explain the difference in latency.
12 (edited by tofer76 2024-07-12 05:49:14)
Yes, that's right.Can you advise me how to solve the problem? Are the old drivers compatible with ventura?
Maybe roll back to an older mac os?
Unfortunately, it is not possible to attach pictures
On the new mac I would try install the 331 driver. Follow the readme in the driver download.
Do I need to remove the installed drivers? or can I put it on top?
put it on top, the installer will replace the old
thank you very much! I figured it out. It wasn't about the drivers, it was about the live professor. Thanks to everyone who responded
You may reveal what exactly with Live professor was the problem ?
In the latest version of the program 2024.0.3, the latency was 4 ms for input and output. I installed the old version 2022.3 on both computers, the latency was 0.7 ms on both.Driver 410 driver returned to the new mac. I think something has been changed in the program, perhaps to add support for multicore? I did not find any information on this issue in the program support. Once again, thank you all very much!
Glad you can work
