Topic: [Solved] Headphone output not recognized by computer ?
Hi, I'm in the process of setting up the RME adi 2/4 pro SE.
I download the driver, and flash updated the firmware.
I'm connect via USB to my PC (windows 10). 2 analog inputs are plugged in, as well my headphone jack in the 3/4 output, as instructed in the manual.
However my computer doesn't recognize the headphone output, it only sees the analog inputs (in the windows 10 output settings).
In the SETUP > OPTIONS > PHONES menu, here is how it's set up :
Dual Phones > OFF
Bal TRS Ph mode > OFF
Toggle Ph/Line > OFF
Mute v. Ph 1/2 > ON
Mute v. Ph 3/4 > ON
In the I/O > Phones out 3/4 menu, here is how it's set up:
Source > Auto
Ref Level > Lo Power
Auto ref level > OFF
MONO > OFF
Width > 1
M/S Proc > OFF
Phase Invert > OFF
Crossfeed > OFF
DA filter > Sharp
De-emphasis < Auto
Dual EQ > OFF
Volume > -15 dB
Lock Volume > OFF
Balance > <C>
Mute > OFF
Dim > OFF
Loopback > OFF
Dig DC Protection > Filter
Rear TRS Source > Line 1/2
If I change the Source to Analog, at least I get to see a signal in the interface (why did the interface not see it by itself in auto mode btw ??), but still not detected by my computer anyway, so it doesn't fix the problem.
I could simply plug my headphones into my computer directly, and it works using the computer's own crappy amp, however the volume there is too weak to monitor the analog signal, and is not good quality.
I just want to be able to plug into the 3/4 phone output and monitor from there what's happening in my DAW and in my computer, similarly to how it works on the UCX II.
