Topic: Is this routing possible with the ADI-2/4 Pro SE?
I'm trying to understand if it's possible to route a signal that is coming from software (in USB mode) to a specific digital output, and then route a different digital input to the analog outputs that I am using for monitoring. I have read the manual but did not see much about configuring sources and destinations for the various inputs and outputs, though it's possible that I misunderstood something.
My use case is to insert an additional digital processor in the monitor chain while monitoring a signal from a DAW or similar, and still use one of the ADI 2/4's analog output pairs for DA conversion before my speakers. The other pairs of AD and DA would be used for pitch/catch through an analog processing chain. All of this is in the context of mastering music.
I have seen the Lynx Hilo configured in this way, and it is ideal for my workflow. I am hoping that the ADI-2/4 can be configured similarly. Does anyone know if this is possible? What am I missing in the manual if so?
