MC wrote:I don't see where Dorrus vdv talked about DAWs. For drivers there is no start from scratch necessary.
Hi Matthias. Since he already has a UCX, I assume that he has already configured some things in TotalMix FX, i.e., probably created one or more snapshots for several routings / application scenarios.
Wasn't it always said that you can only continue to use them if the new device has the same port layout? This is not the case here, and I would like to point this out.
This has nothing to do with a DAW, I'm more concerned with the fact that you might have to redo the existing routings / TM FX snapshots from scratch because the UCX II doesn't have the same port layout (but one more AES port).
