Topic: Best input choice to connect a mixer
Hi.
I'm using a summing mixer with balanced outputs, both TRS and XLR. To connect it to my UFXII and tried XLR->Front XLR Mic Input as well as TRS->Rear TRS Input.
Now since the specs of the rear TRS inputs, front XLR and front TRS inputs all differ slightly I'm wondering what is the best/recommended connection?
FWIW, the XLR->XLR connections comes in about 5dB lower than the rear TRS @+4dBu. I volume matched both connections (TRS->rear TRS and XLR-> front XLR) and made a null test which results in a ~-20dB difference IIRC. Se there are quite some differences.
Any recommendations or does it just not matter?
Thanks,
Bo
