Topic: RME M32 AD problem with recognizing analog channels
Ive got MADIFace with M32 DA and M32 AD. I have problem with DB25 x8TRS connection to M32 AD. When DB25 is connected to Line 1-8 in AD channels are routed like this
DB25 chan.1 is going to AD INPUT 8
DB25 chan.2 -> AD INPUT 6
DB25 chan.3 -> AD INPUT 4
DB25 chan.4 -> AD INPUT 2
DB25 chan.5 -> AD INPUT 8
DB25 chan.6 -> AD INPUT 6
DB25 chan.7 -> AD INPUT 4
DB25 chan.8 -> AD INPUT 2
As you see it goes only to even numbers INPUTS and its doubling. What could causing these? Bad soldering of DB25 cable or maybe bad configuration of RMEs devices?
Thanks!
Re: RME M32 AD problem with recognizing analog channels
If you change sample rate from 96 to 48 is there a change ?
3
That sounds like the Tascam cable is soldered incorrectly. Where did you buy this?
