I would only consider network-based setups (Dante or AVB) if you are mainly working with one fix sample rate. With MADI, the clock slaves usually follow the clock of the master automatically. Unfortunately, this is not the case with network-based setups. Here, each device or stream must be reconfigured if there is a change in the sample rate. There was already a thread about this in the forum.
See also comment RME: https://forum.rme-audio.de/viewtopic.ph … 89#p195989
AVB then also has the requirement for an AVB-compatible switch. Dante costs extra because of the Audinate chip, and you have to set up Quality of Service on your switches, possibly also routers if you have to route between different VLANs.
With MADI, you don't have this additional operational effort when changing the sample rate and all the additional requirements. MADI is then also definitely dedicated for audio.
If you need several MADI buses for any reason, then take a look at HDSPe MADI FX and MADIface XT II.
If you are also interested in Room EQ, the following interfaces with MADI support may be of interest to you:
USB3 based: UFX III, MADIface XT II
PCIe based: newer versions of the HDSPe MADI FX
MADIface USB (2.0) is also possible: one MADI bus, no Room EQ
