1 (edited by Geert 2008-10-22 14:38:46)
Topic: Octamic no signal input!
I've finally received my ADC Module for my RME Ocatamic.
NOw I've installed it, but it doesn't seem to work.
EDIT:
I've got it running, but I only get pops & crackles when I try to record.
This is my setup:
I've got a RME Octamic D & Motu 2408 MKII
I have set it up like this:
MOTU Configuration:
Clock Source PCI-424: Internal
Bank A - 8 x analog input
Bank B - ADAT (inserted in port B in the back in ADAT in) and enabled all 8 tracks
Then on my octamic I have pin settings:
1,2,6 to the bottom and 3,4,5 to the top.
This should indicate that it takes is Clock source from the external device (the Motu 424 card).
I've got BNC & ADAT cable between both devices which should be sufficient I think.
But I only get pops and crackles!!
Anybody got a clue?
Please advice if it needs to be different..
