Topic: RME Babyface Pro FS x Focusrite Octopre MKII ADAT dropouts
Hi!
Hopefully this is the right place to answer this question,
I've been having some issues for a whole now with my babyface pro fs connecting with my octopre mk2 via adat.
The ADAT is all set up correctly as far as I'm aware. They both sync and work correctly together
However roughly every half an hour to an hour, I will experience some signal dropouts/the resolution of the audio goes really low for about 2 minutes. Sorry if i'm not using the correct terminology but it's the same as when my CPU becomes overloaded when running a billion plugins on ableton.
Any sort of insight into this or resolution would be appreciated as this has been a pain for a while now
Thanks!
