Topic: Totalmix issue
Hi to everyone, when I scroll up and down the knob of my fireface uc to move the fader of the stereo channels on the totalmix, also is moving the pan. It didn´t make it before and I didn´t touch nothing of the setup. I installed Cleanmymac app and I did an analize. could you help me please? thanks.
Re: Totalmix issue
Never heard of this issue, did you try a Total Reset in Totalmix ?
Menu Options / Reset Mix / Total Reset.
3 (edited by ramses 2024-11-25 11:39:37)
Re: Totalmix issue
Double post .. ok so I reply here *sigh*
Make a backup of your TM FX workspace.
Then you have these options:
1. restoring a backup of your TM FX workspace where it still worked (in case you make backups of your workspace)
2. reset TM FX and retry whether it makes a difference, you can restore the backup of TM FX workspace later
In case, you have good admin skills for your computer setup and a proven disaster recovery strategy...
- backup current state 1st to be able to come back to here, best OS and user data / settings (of the WHOLE system)
- restore the system to a day when everything still worked ok
If also TotalMix FX / the unit works as expected, then you most likely have no HW problem and could think about perhaps staying in this state and only restoring user data.
But I do not know your admin skill, or how well you are prepared to handle such situations. Do it on your own risk...
EDIT: Most likely the issue is ... see next posting #4
Re: Totalmix issue
Sounds like the front panel knob is not in 'gang' mode and is only changing the level of the left signal.
P.g. 38 UC manual.
"Stereo Mode
Pushing the knob for more than a second activates the Link (Gang) mode. The display will show
off or on. In stereo (on) mode, the display only presents the left channels of a stereo pair (L1,
L3, L5...). The gain and volume setting is then valid for both channels."
