Topic: Loopback Problem - not re-routing possible?
I know that Loopback is supposed to not show any signal in the input row of Totalmix FX. But I thought it was still possible to reroute the back-looped audio from that input channel to other outputs. So far, I had only used Loopback to record audio playback in my DAW. But currently investigate Totalmix and my Madiface XT and its capabilities to do bass management for my 5.1 monitor setup. The plan was to route all channels except for the LFE to an additional (unused) output and set all of those channels on loopback. The corresponding input channels can now be EQed accordingly and and sent to the subwoofer. I did not want to send those channels to the subwoofer directly, because the LFE channels should not get any low-cut filter. I had hoped that I could somehow circumvent that by using loopback, but now I found I could not re-route those looped inputs to the sub. Am I doing something wrong or is this by design? Can Loopback-audio fact only be received in other apps, but never in Totalmix itself?
