Hi we are having some strange problems with our MIDI Remote 1.6 for Micstacy Firmware 2.1
MADI Face (latest firmware + latest driver)
The Midi Control will show "no response"
I reduced the setup to 1 MADIface and 1 MICSTACY in an optical or coax connection.
MIDI set to optional in Micstacy and MIDI ports to MADI in Midiremote
Originally I thought it was a connection problem, because our long optical MADI cables connectors are getting old.
But:
a) Audio works fine through the whole system (even with a bigger Setup) going all the way through the loop twice and auditioned
b) no Audiodropouts, no ASIO lost or anything
c) I used different short optical cables as well as Coax connection
When I briefly switch the MADIface from optical to Coax and back it will show Online for about 1 second, then NO RESPONSE
I changed the whole setup part by part
Micstacy
MADI-Expresscard
MADIface
Laptop
nothing helped
then I changed the FW cable (both were original short ones)
THEN it suddenly worked
but only for 1 day
Any good suggestion?
Is the MIDI signal more critical then the Audio?
All the best,
Thore
