Topic: Multiface II Feedback loop
I have several speakers set on the analog outputs of my Multiface and I use a measurement microphone for measurments - If I connect the Mic to analog input 0 it seems to work and I can record my measurements . If I connect the mic to input 4 and leave input 0 open the mic feeds back directly with the speaker on output 0 as soon as I turn the amp and microphone on- This damaged my speaker and I didn't want to do it again,. If I do not have anything connected to output 0 then I don't have a problem with the other channels
Why is this happening? Does the analog input default to output 0 unless the 0 input is used. I seem to have solved the problem but I wanted to be sure I understood why so I don't blow up more speakers.
Tom
