Randyman... wrote:So you are using the ADI-648 simply as a master BNC wordclock at the moment (and not for any MADI>ADAT conversion)? I haven't used the ADI-648, but if it presents a clock on the ADAT output ports even w/o any MADI connections, then it should work. I believe Sync should line up without issues assuming the MOTU isn't doing anything weird to the clock (the MOTU's ADAT clock should still be in sync with the MOTU's BNC input, therefore also be in sync with the ADI-648's ADAT ports). I prefer Wordclock/BNC to sync multiple units, but your Digi9632's don't have WC BNC IIRC.
Just curious - which MOTU interface has 5 ADAT output ports? I'm assuming you have multiple MOTU BOB's on a single MOTU card? Sounds like a flexible and powerful setup you've got there
Yes, the ADI-648 is only providing wordclock for the MOTU interface(s) right now, but I would like to explore the possibility to use the ADI's ADAT outputs to sync the PC's that are now sync'ed by the MOTU's ADAT outs. And yes, I believe the ADI-648 provides sync on the ADAT, since it is also meant for stand-alone use and has internal/external clock capabilities etc.
Right, wordclock on all machines would be the best but I can't equip all the PC's with WC unfortunately.
I use a PCI-424e card which has three firewire connection going out to 3 MOTU 2408's. Each of the 2408'ss have three ADAT in/outs.
Thanks.
Simon
