Topic: Multiface I just stops working after 5-10min
HI Guys,
Hope you can help out with the Multiface I (S/N 22208366) + CardBus (S/N 22205878). On WinXP SP3 platform.
What happened was that after I have updated the firmware (hardware revision 17/55) and the driver Ver 3.082 as instructed, the multiface seemed to work fine, until 5-10min later it would just stop working. There was no flashing red light from [host/error]. I clicked on the DSP Hammerfall settings menu and it showed I/O Connection as error. The only way I could get it to run again was to power off everything including the mains. Power up again and the [host/error] light would lit up continuously until my laptop has loaded fully with its drivers, then the light would go out. Everything works fine until 5-10 min later and it would just die again.
I noticed if I turned off the laptop earlier, there would not be any red light flashing as in the past (with previous drivers?).
Is this a software/driver or hardware problem?
Much appreciate your advice. Thanks.
Mike L
